This Good or Bad
Discussion in '1947-1954' started by Purec4, Aug 24, 2011.
  1. Purec4
    Purec4 Member
    Kingsport, TN
    Finally Id the motor it's a 292 six between 63/72. I know nothing about these motors except that I read they were built for the trucks and had a taller deck... So please chime in as to weather its worth working on or switch to a SBC. I dig the looks of the inliner, but is it going to be trouble. Wanting to build a driver.... thanks :confused: Also how do I ID the trans?
  2. drabo
    drabo Member
    Patrick AFB, Florida
  3. ol' chebby
    I could haul that off for you......
  4. Purec4
    Purec4 Member
    Kingsport, TN
    If I can't decide on a route to take this project, just might take you up on that!...:D Hope I'm not in over my head
    292 cid l6
    This is the engine for the Rockabilly ' Resto Rod ' guys ~ it's a thinwall , long stroke design and unless you over rev it or fail to do routine oil & filter changes , it's terrific .
    Take the time to adjust everything on it and make it run , you'll prolly like it better for a driver truck , I certainly would .
