Lowering a stock framed 54
Discussion in '1947-1954' started by Purec4, Sep 15, 2011.
  1. Purec4
    Purec4 Member
    Kingsport, TN
    Not much in the way of search results sooooooooo. Anybody here lowered their truck and kept the stock frame and straight axle? Results? how low were you able to get it? Have a 54 3100 I recently got and and want it lowered, not ground scraping but just a good stance. If not looks like it will be Gasser time.
  2. federale
    federale Member
    Washington C.H.,Ohio
    Re:Lowering
    About the only way you can lower it and keep everything stock would be through the use of lowering blocks. They should be available at most any FLAPS store.
  3. Purec4
    Purec4 Member
    Kingsport, TN
    Right, but has anyone modified or changed out the spring hangers on the front and rear springs in addition to blocks or instead of? How low is safe on the front springs with out running into steering problems or should I say creating?
  4. 1 Hotrod
    1 Hotrod Member
    Wisconsin
    There's a couple of ways to do the front, you can get a dropped axle in a 3 or 4 inch drop. Or else Posies or Eaton Springs sell dropped springs. Posies sell a 3 inch drop and Eaton sells 1,2, or 3" drop. Same for the rear and if your using a late model rear end you can get the springs with the centering bolt relocated so the wheels sit centered in the wheel openings. I have also read that you can replace the rear spring hanger with ones from the front .
    http://droppedaxles.com/CHEVY_AXLES.html
    http://www.eatonsprings.com/
    http://www.posiesrodsandcustoms.com/
  5. Zig
    I'm using 2" dropped Eaton springs. In a few years, I might actually have the fenders back on the front to see what it will look like. If it's not just right, I could downsize the height of the front tires just a tad... Hopefully, that won't be needed.
  6. DeadZoneTruckin
    DeadZoneTruckin Member
  7. Guest5979
    Guest5979 Guest
    lower
    what i did was de-arch the springs and removed one leaf from each leaf pack
    got her down 5 inches not ground scraping but good stance.
    Robert
  8. ccharr
    Here is a shot of Roberts truck at the Brothers Show waiting for the gates to open. And a shot of mine seating across from Robert in line waiting for the gate to open, mine is a 1ton and has had s few leaves removed to maake it sit lower.
  9. Volker
    Volker Member
    Germany, nearby Leipzig
    remove leaves
    i've done for an experiment the same. took out 2 leaves from rear -it's OK but in front 2 leaves the truck was too smooth in curves and jump up and down if i drove througt rough streets. Is it normally or have i a problem with my shocks?
