Where does the ground wire go???
Discussion in '1960-1966' started by 61apache30, Jan 22, 2004.
  1. 61apache30
    61apache30 Member
    When I bought my 61 apache (235 cu in) the ground wire to
    the battery was missing. Where does this battery ground
    attach to the motor? I connected it to the thermostat
    housing so the starter would work but I know it goes some-
    where else on the motor. Does anyone know exactly where?
    Also the ground strap from the starter to the frame was
    missing too. I assume it goes from the bottom starter
    mounting bolt to one of the two holes on the frame near
    by?
