1962 Chevy P/U
Discussion in '1960-1966' started by ic455, Dec 28, 2003.
  1. ic455
    ic455 Member
    Murray USA
    Have a '62 Chevy and need to know how to be sure if it is 1/2 or 3/4 ton. It is a long wheel base with 6-lug wheels, drums all-around, coil springs and hydraulic clutch. THANKS!!
  2. 62fleet
    62fleet Member
    Newman Lake USA
    Just to let you know, I have two 3/4 ton pickups. They both have 8 lug wheels on them. another way to tell is to look at the panel by your left laeg when siting in the truck. There will be a small metal plate that will list the gross vehicle weight too.
  3. cowboy
    cowboy Member
    all 1/2 tons from the 60's are 6 lug as far as i know and 3/4- 1 tons had 8 lug.
    Cowboy
  4. ic455
    ic455 Member
    Murray USA
    Thanks!! Any leads on resto parts?
  5. ic455
    ic455 Member
    Murray USA
    Thanks!! Would you happen to have any interchangeable body parts for sale? I need pretty much everything!!
  6. Tony 61
    Tony 61 Member
    62 cab&front clip some rust some dents but in canada ;)
