Teaching point- U-Joints
Discussion in '1947-1954' started by Flashlight, Oct 13, 2011.
  1. Flashlight
    Flashlight Member
    So I've got a little clunking if the motor lugs a bit, I see some chaffing near my dual exhaust pipes, and there's maybe 1/8" slop at my U-joint.
    I will get the pipes moved out a bit. Could be my 'magination;) and maybe a light wobble at 40 MPHish going down the road, but it is a 53' with open shaft.
    Can someone educate me on field diagnosis of a Universal going bad, signs and symtoms?:confused:
    Flashlight
    If the 1/8th inch slop is actually in the U-joint, it is not GOING bad, it is already there.
    Stop now
    Before it fails whilst you're driving and the propshaft decides to dance the dance of death , taking your truck with it.... :eek: .
    I'm amazed you didn't mention any rumbling or grinding noise when under throttle .
    Be sure to make sure the 1/8" slop is the cross inside the yokes and not the yoke slopping on it's shaft , that's a whole 'nother ball of wax .
    Once you have the old U-Joint out , take the time to polish the inside of the yoke's holes so the new caps will slide right in by thumb pressure like they're supposed to .
    Work over some clean towels and if a cap stops going in STOP , remove it and have a look see , maybe one roller bearing has fallen out of place . - I always glue them in with some stiff grease .
    If you mindlessly hammer a cap in after polishing so they'll slide in , you'll bend , break or otherwise ruin a roller bearing or more and no , you cannot assemble it with bent / broken or missing roller bearings , not even one .
