235 only runs with carb choked
Discussion in '1947-1954' started by dan cocomise, Oct 13, 2011.
  1. dan cocomise
    dan cocomise Member
    checked for vacume leaks at carb intake vacumeadvance wipper hole pluged.carb was resently rebuilt and ran ok till now.whith carb choked at low idal 19 inch pounds runs rough. thanks
  2. ol' chebby
    Have you monkeyed with the idle mix screw?
  3. ol' chebby
    Spray around the butterfly for the throttle plate with wd40 to check for vac. leaks there also.
    Once In A While
    The Bakelite base spacer will crack and cause a serious vacuum leak , it'll prolly run fairly well off idle but will not idle atall unless the choke is pulled out .
    Dismount the carby and gently raise the Bakelite spacer off the intake manifold , unless it's *perfect* , it's junk .
    NOTE : no gasket is used between this spacer and the intake manifold .
