steering wheel pics
Discussion in '1947-1954' started by bowtiesr4me, Oct 15, 2011.
  1. bowtiesr4me
    bowtiesr4me Member
    Evington VA. USA
    Hey guys,
    anybody got any pics of the factory steering wheel / horn button design.
    I wired my horn up in the original column and wheel but now it blows everytime i turn the wheel:eek:
    My truck is a '48 . Thanx in advance.
    Mike
  2. Zig
    Just drive straight then~ Sorry, couldn't help it.
    I know that Ken has posted a link to the shop manual, and have seen it here by others. If someone doesn't step forward, I'll catch that for you tomorrow. I believe I book marked it. That has to be a bit maddening, no?
  3. bowtiesr4me
    bowtiesr4me Member
    Evington VA. USA
    Tried that Zig, but my arm got tired of waving at folks and I kept running over mailboxes:D
    I looked thru both of my manuals but nothing about the horn button hookup. It stops at rhe horn bearing at the top of the column. I have the supplement and the repair man. What ever help would be appreciated. I know i'm leaving something out or not putting something in:confused:
    HAGD!
    Mike
  4. federale
    federale Member
    Washington C.H.,Ohio
    Re:Horn
    So Mike, did you pull the horn wire out of the column to make sure it didn't have a bare spot? Most of the time it will rub inside the shaft and cause the horn to blow. HTH
  5. Flashlight
    Flashlight Member
    Ah Yesss.....I spent a few hours playing with my Horns. Turn things a little too tight and it honks, The contacts are tempermental. On my 47 it only works if I hit it in the upper left quadrant.
    I had to grind some solders and contacts, pry it in another spot to get things just so. The repo's parts are not the best quality.
    Flashlight
  6. ol' chebby
    Unfortuntely, few are.
  7. bowtiesr4me
    bowtiesr4me Member
    Evington VA. USA
    When I ran the new shaft in the column the wire looked great,but it was the old assbesstus covered and real brittle...........I guess I might have to look at that again and even the solder spot too.
    Thanx guys.
  8. Zig
    Apparently the manual must be on another computer. I can't find it on this one...
    I was thinking about the wire that comes out of the column also. I want to replace mine, and I'm curious as to how it comes out.
    Good luck, Mike.
  9. Flashlight
    Flashlight Member
    It runs straight down the column...then exits the column under the dash area through an eyebrow slit in the column IIRC. There is a small retainer nipple on some...others just slide out without a fight.
    Flashlight
  10. ol' chebby
    Pull your wheel. The wire is atached to the retainer bearing pressed into the top of the column tube. This prys out and a new replacement has the wire and bearing in an assembly. Remember to tie a string to the old wire before pulling it out! You can then tie the string to the new wire and pull it right out the hole in the column. The bearing just press fits in the shaft. It will usually quiet down the grinding bearing noise when you turn the wheel.
    As far as the horn honking, you need to study the contact. It is hitting metal at some point in the wheel travel. I went through this with the F%&d I just did. Check the little spring loaded insert thingy between column and horn button that goes through the steering wheel.
  11. Zig
    Thanks, Russ~ I'm now looking forward to replacing that!
  12. vwnate1
    Horn Wire
    I just got some heat shrink tubing and used it over the original wire that had bare spots , works great , I hate the crappy repop parts .
  13. bowtiesr4me
    bowtiesr4me Member
    Evington VA. USA
    Thanx Nate ! Ill give it a try.
    Olchebby,
    you don't wont many people ceing u drive a f%#d so make sure the horn is working or just unhook it:D
    Thanx all!
  14. ol' chebby
    This one I will allow myself to be seen in.
  15. vwnate1
    SWEET Brand 'F' !
    All it needs is proper wheels and scrap that V-ate mill, drop in a nice correct 240 CID L6 with C-4 or maybe a three on the tree and over drive....
    These were specifically designed by the FoMoCo for " Gentleman Farmers " and they hit the target dead center , too bad they flexed so much the design was dropped :( .
  16. ol' chebby
    It was an origional V8 (292 Y block) with a 4speed on the floor. It now has a 390 FE with a 5 speed on the floor.
    It now Hauls A$$! and is a very nice driver.
  17. Zig
    Yeah~ That IS a beauty.
  18. bowtiesr4me
    bowtiesr4me Member
    Evington VA. USA
    Ol Chebby u r correct!
    The UNI-BODY is SWEET.
    I use to have one but mine had the flo-thru screen tailgate on it and was mint green. 289 w/ orig. 3 on the tree.( Many moons ago.)
    I would be proud to drive that also.
    Mike
