rear suspension
Discussion in '1947-1954' started by alleycat, Oct 16, 2011.
  1. alleycat
    alleycat Member
    Hi all
    Do any of you guys know where I can get the bushings that go in the pad that holds the rear springs to the axle? I have looked every place I know of and no luck.
    thanks
  2. mobileortho
    mobileortho Member
    Hampton, VA
    Note quite sure of exactly what you're looking for. The springs shoud bolt to the axle perch. Are you refering to the spring eye bushings?
  3. Elky67
    Elky67 Member
    Bavaria South
    Bushing
    Hi alley, assuming you also have a GMC, i guess you mean the pad, that is holt
    to the axle by one big bolt and the pad is secured to the springs with two u-bolts?
    I try, to attach a pic for better understanding. Look in the red circle...
    Didn´t find these either. A friend of mine bought some polyurethane one day and didn´t need it anymore, so i drilled out the rubber remaining´s, used the old metal sleeves in there again, and pored in the polyurethane, let it sit for 12hours and was ready to use them again.
    Hope this helps;)
  4. alleycat
    alleycat Member
    yep, those are the one's I need. Also I need a pic off the rear brake assembly.
    thanks
  5. alleycat
    alleycat Member
    Hi All:
    I cheked his log and found everything but the rear brake assembly. also looked in the archives and couldn't find what I was looking for. Still looking for a pic of the rear brake assembly.
    thanks
    Brake Diagrams
    Make sure if you have Huck or Bendix brakes then go to Chevrolet Obsolete , they have very good diagrams as does " The old Car Manual Project " .
