Fuel Pump Question
Discussion in '1947-1954' started by graham, Dec 19, 2011.
  1. graham
    graham Member
    Houston Texas
    I'm looking to move my fuel tank to the back of the truck. I don't know if the stock pump has a enough vacuum to get the fuel to the pump. I'm looking at a top mount fuel outlet. Do I need to add a electric fuel pump to help it?
  2. ol' chebby
    Stock will work fine. An electric booster pump will help if it sits for a while, but stock will work fine.
    Electric Fuel Pump WARNING !!!!!
    It is VERY important that you use a 4 # MAXIMUM pump ! .
    It's usually sold out and they'll try to sell the the 4 ~ 7 # instead saying it's the same , it isn't .
    You always want the E - Pump as close to the fuel tank as possible .
  4. graham
    graham Member
    Houston Texas
    If the stock pump will work then I'm not go going to change it but if there is a problem then i'll do electric fuel pump. Thank for the help
