Vent Window Channel 1965 C10
Discussion in '1960-1966' started by almostdone, May 24, 2005.
  1. almostdone
    almostdone Member
    Jackson
    Anyone know where I can find 2 vent window channels (metal channel vent window class and modling rest in -- L&R) for a '65 C10?
    Thanks for the help!
  2. dvalentine
    dvalentine Charter Member
    Sacramento
    Right HERE !! Click the Online Store button underneath the red truck at the top of the page. Select your year in the left column of the next page and go to town !
    DVal
  3. almostdone
    almostdone Member
    Jackson
    Thanks but Chevy Duty only provides glass and molding...
  4. 58 chevy
    58 chevy Guest
    Yes we do offer that division bar, it is part # 03-456. It has no holes drilled and the bracket on the bottom of your bar will have to be reused and welded or rivited on to this new one- it is the same for left and right.
    Jesse Hazell Chevy Duty Tech.
  5. almostdone
    almostdone Member
    Jackson
    Thanks. Maybe I am not explaining what I need correctly. I am searching for the metal channel that the triangular vent window glass is installed into which is then rivited to the vent window assembly. Glass is in good condition but the metal channel has rusted through.
    My division bar is in ok shape. Good to know you have the division bar...may need that also.
  6. dvalentine
    Sacramento
    Aaaaah... Now I see !!
    I'm not aware of any remanufactured in the aftermarket. This will be a wrecking yard item, e-Bay, or local paper. My paper has a section for vehicles being parted out.
    The vent window assemblies appear pretty regular on e-Bay. Keep an eye out over there.
    Dont forget the Parts Wanted section here at ChevyDuty.
    DVal
  7. chevynutty88
    chevynutty88 Member
    lmc truck [s what you want
  8. Lakeroadster
    Lakeroadster Member
    Central Colorado
    :eek: Responding to a 7 year old post and suggesting use of LMC parts on the Classic Parts forum :confused:
