lost keys
Discussion in '1947-1954' started by herman quail, Feb 22, 2012.
  1. herman quail
    herman quail Member
    Black mtn, NC
    I have the ignition,glove box,and both door handles for my 53 chevy. I don't have any keys.
    1)Is it possible to get new keys,and did this truck come with more than one cut of keys. what do I have to do to get new keys for this truck
    2) with the stock ignition that worked with a push button starter ,I am changing to a v-8, 12 volt. What do I do, keep original key ignition, I add a push button starter or change the ignition to one that has a start function.
    Thanks Steve
  2. fab51
    fab51 Member
    Central Missouri
    Steve-
    These trucks originally used the same key for all three locations. If you have any record of the original key number, a locksmith can create a new one for you from scratch. Otherwise, I'm not sure.
    As far as your switch, it is entirely up to you. Before I realized that the 6v and 12v starters had different gears, I was going to use a key start 12v starter. I went to my FLAPS and picked up a key start switch that fit in the dash without alteration.
  3. DeadZoneTruckin
    DeadZoneTruckin Member
    This is where the original GM dealership Master key ring steps in to save the day.
    Never had a lock on a truck yet... that didn't match a key on this ring.
  4. herman quail
    herman quail Member
    Black mtn, NC
    I have no information on the numbers of the original key. Now what??
    Dead zone- are you saying take the lock to a chevy dealer??
    steve
  5. DeadZoneTruckin
    The GM dealers no longer stock master key rings from trucks from the 50's.
    I am lucky enough to have a GM master key ring from the 40's & 50's & once I find a key on the ring that fits a lock.....
    I just go & get a copy of that key made for $1 at Ace hardware.
    If you don't have the luxury of a GM master key ring.... you will have to take each lock cylinder into a locksmith & hope he don't rake you across the coals to make a key that fits your cylinders.
  6. Bill Hanlon
    Remove the door or glove box lock (less wear on them) and take it to a decent locksmith who will make you a new key (might as well get two). It will cost more if you stand there waiting for it.
  7. 1 Hotrod
    1 Hotrod Member
    Wisconsin
    Got any friends with 40-50s Chevy's? If so try there keys.
    Keys
    That's a nice ring of keys but it's not a dealer master set :rolleyes: .
    There's myriad ways to get keys , any competent Locksmith can make you one for $6 , then the usual $1.50 copies .
    If the Locksmith wants to gouge you , ask for the Auto Club discount .
    Or , take the lock cylinder to all the thrift & antique stores in your area and begin trying the dozens of old GM keys they'll have lying around , same deal in any swap meet , there's always lots of rings of keys , ask first how much for an old key , then if they say a reasonable price , begin testing them .
    Most used car lots have large amounts of random keys too .
    Don't replace the original ignition switch , just get a heavy duty pushbutton from your FLAPS , they all carry them .
  9. herman quail
    herman quail Member
    Black mtn, NC
    I was thinking of going to a lock smith, hope we have a good one in Asheville N.C.
    I was hoping to here that I should keep the original ignition switch.
    Thanks for the help guys.
    Steve
  10. Flashlight
    Flashlight Member
    I was able to take the off-on-start cylinder from the key start era and with my dremel grind the three grooves that secure it to the original backing from the oriiginal, then with washers i think that were 1 1/4 or an 1/8th from farm co-op, build it up as needed and stuck it through the original hole in the dash. Use the chrome lock ring to hold the washers tight. looks great and I don't need to carry channel locks around anymore when the after market cheapy comes loose.
  11. Flashlight
    Flashlight Member
    ORR!!! Nates idea of making the old foot pedal starter into a starter button was cool too. He's pretty keen for an old feller.
  12. herman quail
    herman quail Member
    Black mtn, NC
    I dropped of the two door handles off to the lock smith. H will make a key and make sure both door handles are keyed alike then he will check it on the glove box and ignition. he will do this for $20-25, not quite the $6 that Nate thought.
    Steve
  13. herman quail
    herman quail Member
    Black mtn, NC
    i don.t know if the door handles are from the same truck? I have been gathering parts since 1987. not complaining just talking.
    steve
  14. Flashlight
    Flashlight Member
    I heard a complant
    Well...Just sayin'....I overheard a guy at the swap meet say "Nate still had the first dollar he ever made":eek:lol
  15. vwnate1
    I'll Take That ~
    As a compliment , not a complaint :D .
    Being fiscally conservative is a hallmark of The Good American , especially Farmers & Tradesmen .
    My 42 year old CHEVROLET truck is parked by the curb , still giving good daily service , it is surrounded by fancy - schmancy new fangled SUV's & Luxo-Barges , all of which will be scrapped out in 5 years or so , I expect my Chevy to provide me with reliable , economical transportation for years to come , all at a fraction of the price of the cheapest new truck .
  16. ol' chebby
    You can order a keyed set from our host......Ignition, glove box and 2 lock buttons.
  17. vwnate1
    ~o.b.t.w.~
    I $pent that first Dollar on some used tools , the better to make more Dollars with :rolleyes: .
  18. Flashlight
    Flashlight Member
    It was a Compliment...of sorts. I always admire your ability to think on your feet and figure out an alternative part or way to do something. Good ol' Yankee ingenuity!
    But, a little good natured heckling and a sense of humor is good too! Mi Amigo.
  19. DeadZoneTruckin
    Heck.... Me & Nate have been heckling each other for over 10 years now :D
    Nate... please expand on your vast database of knowledge on why you say this not a GM dealer master key set :p
  20. vwnate1
    Heckling
    Is good ! :) .
    Your big old key ring has many non GM key blanks on it , the old Master Key Rings didn't , I remember them well .
    I just have random old GM keys , your ring works much better I know ~ the more keys , the merrier .
    You alls keep me on my toes and I like it :p if you didn't like me , you'd never tease / heckle / harrass etc. me :rolleyes: .
