oil
Discussion in '1947-1954' started by benborden, Mar 22, 2012.
  1. benborden
    benborden Member
    nb
    Another newby question.. What oil should i be running in my 54 235? not having smoke issues but ive been using 30w non detergent. Good or bad? i have a slight knock now hoping itll clear when i do my valves hopefully this week.. is my oil too viscous??
  2. Flashlight
    Flashlight Member
    Uh..OHH! The annual Favorite Oil Question...let me take cover first. I like Mobil 1, 5-30...my 235 and for that matter my 216 is very happy on it.
    Let the shooting begin!
    Flame war !!!!!
    Let me say in advance : you're ALL wrong ! .(even those who agree with me .
    Back on topic , use the thinnest DETERGENT multi-vis oils you can find , synthetics are best .
    Does it knock under load or when you let up on the throttle ? .
    Might it be piston slap ? .
  4. Flashlight
    Flashlight Member
    Why nate, it sounds like we agree on this?? Or maybe I was won over in some previous year. Everything i own is on Synthetic Oil......price is hardly a factor anymore.
  5. Kens 50 PU
    Before the "oil wars" start, just let me say: As long as you keep oil in it and change it religiously, it doesn't matter what brand it is. Ready, set, go...:D
  6. fab51
    fab51 Member
    Central Missouri
    My Opinion...
    I prefer 10W-30 in either dino or synthetic blend. I definitely say detergent oil, if you have an oil filter. If you don't run an oil filter, I would stay with non-detergent oil until you find an oil filter to use.
    As always, no matter what oil type or filter or no, frequent HOT oil changes are a must!!!
  7. DeadZoneTruckin
    DeadZoneTruckin Member
  8. benborden
    benborden Member
    nb
    thanks for responding. It actually only will knock a bit under load. i can increase rpm but only gradually..
  9. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    You guys are gonna love this...
    I use 20/50 oil and I have a 10 Qt. oil pan and 2 oil filters....Big Tim :cool: tims pics 025.jpg
  10. Wolf
    Wolf Member
    Kansas
    I got several gallons of Rotella Diesel engine oil for bout 75% off a few years ago. I like it because it has increase wear protectors, zinc I guess. But once its out I will try to find the cheaper synthetic I can get.
    But I have been running that for the last 3 years with no problems. I would say 8-10K miles, changed 4 times.
    But then again I have the GMC, with oil pressure;)
    Ok now I really have started it!!! Go
