roof patch panel
Discussion in '1960-1966' started by rustbucket, Apr 25, 2004.
  1. rustbucket
    rustbucket Member
    New Braunfels USA
    i need a patch panel for the "overhang" that juts out over the windshield on my 63. pre fab doesn't exist, at least not that i've found.
    talking to other folks, this is a common rust through area. thought someone by now would figure out they'd make good $$ making a patch panel.
    anyone have suggestions ?
  2. dvalentine
    dvalentine Charter Member
    Sacramento
    Hi Rusty,
    Nothing you can do but scrounge a cab that still has that part intact.
    If that part of your cab is shot, check the hinge pillars too. The rot is caused by the drip rail losing it's seal and leaking water that runs down inside the hinge pillars unseen. Another sign is the floor rotting right next to the kick panels.
    If you find a cab that still has the roof & hinge pillars in good shape, consider swapping cabs. Less work.
    Dennis
  3. rustbucket
    rustbucket Member
    New Braunfels USA
    boy, you're sure the bearer of good news.
    HAHAHA
    I was afraid of this. I plan on tearing into the cab pretty soon to see the extent of the damage
    THANKS!!!!!!
