Master cylinder & speed
Discussion in '1960-1966' started by Dragginwagon66, Apr 25, 2004.
  1. Dragginwagon66
    Dragginwagon66 Member
    Hi-
    Picking up a 66 one ton Panel next week, and I need to know:
    1. Is there a dual master cylinder bolt-on that I can upgrade to WITHOUT having to install disk brakes? Also, if I buy the ChevyDuty power brake conversion kit, can I use it without having to install disk brakes? And what do I have to do to adapt the brake lines? (It's still original, single master cylinder.) At the end of the day with a dual master cylinder, is one half the brake system split between say, left front/right rear, or is it simply split front-rear?
    2. I've read all the posts on rear-end ratios versus highway speeds. The seller of the vehicle I'm buying has just swapped the rear axle to a three-seventy-three (he said 3:83, but I think he may be mistaken). In any case, with a 292 CI, original 4 on the floor tranny (one ton, mind you) and the three-seventy-three rear, is it reasonable to expect the vehicle will be able to cruise in the 50 - 55mph range without hammering the engine?
    Thanks for your responses and patience with a newbie.
  2. dvalentine
    dvalentine Charter Member
    Sacramento
    [updated:LAST EDITED ON Apr-25-04 AT 09:24 PM (CST)]You don't need to convert to disk brakes to go to a dual bowl M/S.
    A 70's GM truck Master will work for sure, but there are probably a ton of others. Remember that you will probably need a thrust rod, ( the rod that connects to the brake pedal.) of the correct length. You will need to run new hard lines to the front brakes and a new hard line from the m/s to the right frame rail where a T is located for the rear lines. Bleeding the brakes will take longer than installing the hardware.
    On the engine trans rear combo ? If you are talking about a 4 speed with a non syncro compond low 1st gear ? It Will Be Screaming at 55 and 60. That will most likely be as fast as you will want to push that motor on a truck of that size.
    Dennis
  3. Dragginwagon66
    Thanks Dennis-
    I figure to make the brake upgrade my first priority. Having read all the posts on rear/end speed, I was estimating that 55-60 would be near the top.
    Will be a slow trip home.:D
  4. drabo
    drabo Member
    Patrick AFB, Florida
    Jim ##### Trucks makes a bolt-in kit for power brakes. Works with f and r drum set up.
    Brian
  5. tech1
    tech1 Member
    Yes i do carry a dual master cylinder for that truck
    Yes the power brake conversion kit will work with your drum brakes
