Pins (J1115) for pulling transmission
Discussion in '1947-1954' started by put-put, May 6, 2012.
  1. put-put
    put-put Member
    Northwest Florida
    Does anyone have a source or replacement for these pins used in the top 2 bolts holes of the trans as guides for pulling the transmission?
    thanks, PUT_PUT
  2. ol' chebby
    Cut the heads off of longer bolts.
    Tranny Guide Pins
    What Russ said ! .
    I always loose them after the job so each time I do a clutch , Imake up a new set .
    Just take one tranny to bell housing bolt to the Hwe. Store and match it up , cut the head off with a hacksaw and chamfer the sharp edge a bit so the tranny slips right over it ~
    This is one of those Journeyman tricks that ensures long clutch life .
  4. put-put
    put-put Member
    Northwest Florida
    excellent, thanks
  5. Bill Hanlon
    What Nate said + cut a slot in the non-threaded end so you can use a screwdriver to back the pin out instead of trying to back it out with your greasy fingers.
    Fwiw ;
    If you're doing clutch work , you have no business having greasy/oily fingers ! .
    :p
