Brake Lines
Discussion in '1947-1954' started by bdavis, May 5, 2012.
  1. bdavis
    bdavis Member
    Klamath Falls, Or
    Does anyone have any pictures as to how to run the brake lines on a 51 Chevy pickup. I screwed up and didn't take pictures:eek: as to how these lines are supposed to go back in their respective locations. I have looked over the sight but the pictures aren't helping me too much. Thank You:confused:
  2. punisher 74'
    punisher 74' Member
    kcmo
    hate to say it but check the lmc catalog they normally have a ok pic of the routing
  3. bdavis
    bdavis Member
    Klamath Falls, Or
    I have the line from the master cylinder to the t-block figured out and the one going to the back axle but i cant figure out the ones to the front brakes.
  4. bdavis
    bdavis Member
    Klamath Falls, Or
    I tried the lmc catalog but it did not help me enough. thank you for the suggestion though. I appreciate it.
  5. ol' chebby
  6. bdavis
    bdavis Member
    Klamath Falls, Or
    I already have the lines. I bought the kit from the sponsor. I just can't remember how the front lines go back on. I even kept the old ones but i can't get the front one to line up right.
  7. ol' chebby
    You will more than likely have to add a bend or 2 in order to make them fit.
  8. Chiro
    Fun with tubing bender
    I bent and flared my own lines using the old, crusty ones as templates. Took a really long time but came out perfect.
    The diagram you are looking for should be in the "Factory Assembly Manual"
