'62 1/2 Ton Coil Springs and Shocks
Discussion in '1960-1966' started by destryrideagain, Jun 1, 2012.
  1. destryrideagain
    destryrideagain Member
    Kansas City
    I just switched out coil springs on my 1/2 ton C10 62 Chevrolet that had been lowered about an 1" to 1 1/2" with the springs still intact on the truck. I replaced the coil springs with supposedly stock ones from our host, http://www.classicparts.com/1960-72-Coil-Springs-Rear/productinfo/74-481/ and could not fit the shocks up to the rear axle. The shocks I took off were between 21" to 22". It was difficult to find anything longer than those..Bob at NAPA had to go through 60 boxes of shocks to find 23" in length, to fit on. From my research, the original shocks were 19" fully extended. Can anyone shed some light on this? Everything is put back together and the ride is pretty good anywho.
  2. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    New springs will settle in, usually 1 to 1.5 inches over time, you can speed this up however by carrying some weight around with you, maybe a couple of bags of sand or old lumber.
    Coil Springs
    Those appear to be the light duty ones and yes , they'd settle in and droop a little bit soon .
    I'd rather have the heavy duty 1/2 T. springs , I found a set but stupidly didn't grab them and the truck was summarily crushed for scrap :mad: .
  4. markeb01
    markeb01 Member
    Spokane, WA
