Drive shaft issues
Discussion in '1947-1954' started by Elky67, Jul 3, 2012.
  1. Elky67
    Elky67 Member
    Bavaria South
    Hi folks,
    after having the truck on the road for a few weeks, i discovered a grinding,
    whining, clonking noise out of the driveline:(.
    As my truck is a GMC longbox 1/2 ton, i have the drive shaft extension in it.
    I already ordered the u-joints, the bearing etc., but examining the second yoke,
    it seems like it got damaged, due to loose and broken bolts.
    Now my question, would anyone of you guys have a good used yoke available,
    might deadzone have stuff like this?
    I really want the truck to be on the road again soon and be reliable, as summer won´t last forever;)
    Thank you all for any help or trace...
    JOE To The Rescue !
    Yes Joe will have what you need .
    What you need to do now is : take the old bad parts and lay them on clean cardboard etc. so there's good contrast and send him photos of what you need .
    Be sure to count the splines and tell him how many...
  3. Elky67
    Elky67 Member
    Bavaria South
    Pictures...
    Thank you Nate, for your reminder; stupid me, forgot to include the pictures i already made.
    Here they are, hopefully you guys can see, what is important.
    I counted 10 splines...
    ! Ouch !
    Sadly , this isn't as uncommon a thing as you'd think .
    Was Joe able to help you out ? .
  5. Elky67
    Elky67 Member
    Bavaria South
    Lucky me:)
    Nate,
    a buddy of mine, (he´s a milling/lathe machine expert by trade) came by on the weekend and i showed him my damaged and rounded yoke and asked for his advice.
    He told me, to weld on the missing millimeters and then take the yoke on a lathe and turn it down smooth to the desired dimensions.
    For a vehicle with an output of about 90 horses, he wouldn´t see any issues
    doing this.
    I gave it a go on Saturday and i think, it´s nearly as good as new again and hopefully the rest of the parts show up soon; can´t wait, to take the truck for a spin and it should be much more comfortable to drive.
    Thank you anyway for asking, if all failes, i would contact Joe for a replacement, but shipping stuff from the USA to Germany is unbelievable expensive at the moment. A parcel the size of a cigar box is caculated about 30$$$:eek::eek:
    I´ll take a picture and show you the result.
    Journeyman Repairs
    Good ! .
    I'm glad to see you took this route , I hesitated to suggest it because it takes a Journeyman Machinist to do the job , .002" off and it'll shake like a paint mixer forevermore....
    Having access to good help is a real gift .
  7. Elky67
    Elky67 Member
    Bavaria South
    Here we go, with the reworked yoke; i think i´ve welded on about 2mm (0,0787inches), that´s what i thought was missing, compared to the front yoke on the tranny.
    After the welding and slowly cooling down, i turned the surface down, to smooth it out. When this was done, i took the yoke on the milling machine, to
    cut the center part to the exact measurement (1inch).
    Hopefully it´s good to use again another 50+ years:rolleyes:
    By the way, what does journeyman repairs mean?:)
    In the meantime, i added a "new" accessorie to the truck...
    An old oak wine barrel, ment to be the tool box and dry storage area.
    Oaken Keg
    That's a nice tool box there :D .
    Journeyman means one who's a fully competent at his Trade .
    I'm not really good to explain things , I hope that helped .
    Similar to " Maestro " in many other languages .
  9. Elky67
    Elky67 Member
    Bavaria South
    Back together
    Since the missing parts showed up lately, i´ve put it all together. The "okie" bushing wasn´t available, so i made one on the lathe.
    Now i took the truck for a little spin and checked for leaks, as i changed the automatic oil also, while everything was apart.
    My concern/question is, how hot can/should a closed driveshaft tube get, in normal driving condition?
    I tried to touch right at the joint after the tranny and i would say, it was nearly as hot as the tranny case, after about a foot, it was just worm?
    Is this normal, or might the bushing be to tight?
    Thank you alls once again, for any help on this.:)
    Hot Oakie Bushing
    It's too close tolerance .
