oil drain plug leaks
Discussion in '1947-1954' started by dan cocomise, Aug 13, 2012.
  1. dan cocomise
    dan cocomise Member
    Oil drain plug leaks, threds look and fill good.Oil heats up it drips evon more.Any quick fixes. thanks
    FLAPS should have oversize oil plugs. They are just a tad bigger. You don't re-tap the pan.
  3. ol' chebby
    Make shure you have the little plastic or rubber gasket under the drain plug, like some modern cars have, sometimes this will help.
    Oil Plug Weeps & Seeps
    Never , EVER use a ribber drain plug gasket ! .
    Only a hard one , copper , fibre , aluminum , nylon etc.
  5. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Teflon works good too. Glass Filled Teflon, a.k.a. GFT, is good up to 700 degrees. The replacement pan I bought for my sbc many moons ago came with a GFT gasket.
