I'm looking for authentic wheels?
Discussion in '1947-1954' started by wokri, Aug 27, 2012.
  1. wokri
    wokri Member
    Germany
    Hello,
    as you can see have my truck original wheels. I think they look good, I like the original look with the hubcaps. The wheels on my truck are not in a very good condition.
    Can you give me a hint where I can buy wheels which look authentic?
    Ask
    Wolfgang
  2. ol' chebby
    I find them at swap meets. You might see what mothertrucker has.
  3. Root2812
    Root2812 Member
    Coon Rapids, Mn
    Wheel Vintiques makes reproductions and you can order them with custom back spacing if need be.
    New Old Style Wheels
    Stockton Wheel in Stockton , California .
    I'm quite sure you want tubless typ 16" wheels with hub cap clips , not those dangerous split rims :eek: .
  5. wokri
    wokri Member
    Germany
    Hello Nate,
    yes I'm looking for tubeless wheels, but they should be 15".
    wolfgang
    6 Lug 15" Steel Wheels
    O.K. ,
    These are out there , the main thing you now need to decide is : snap on or clip typ of hubcap as there's two different wheels here for this .
    For simplicity , Joe (' Mothertrucker ' ) in Arizona , will sel you a nice set of matched wheels or like I said , Stockton Wheel or other Hot Rod Wheel Suppliers all will make them up for you brandy new but $ ! .
    I'm not rich so I had to keep going to junkyards until one by one I found a full set of 6 lug 15" snap on hub cap wheels for my '69 C/10 , these are also used on earlier trucks and the Tak Force Hot Rodders don't seem to like them much so maybe you can peruse the Task Force forums for some take offs ? .
    Good luck hunting ! .
  7. Bill Hanlon
