Worn shock hole in frame
Discussion in '1960-1966' started by res0bsvt, Oct 15, 2004.
  1. res0bsvt
    res0bsvt Member
    Plano
    I have a '66 Fleetwood with an old worn front shock. The upper bolt hole in the frame has been worn larger and is oval from the loose bolt moving around. What are my options to either repair or reduce the difference in bolt and hole size?
  2. AC1108
    AC1108 Guest
    One option would be to weld the hole up and redrill it. I suppose you could always find a bushing to put in there that is of similar size.
  3. res0bsvt
    res0bsvt Member
    Plano
    Do you think a muffler shop would do the welding for me? I wouldn't mind just using a bushing, if I could find one that works. Any ideas on where to begin a search?
  4. AC1108
    AC1108 Guest
    I imagine a muffler or machine shop would do the welding for you. The only problem I would see with a bushing is that if the hole is much larger than the bolt and a weird shape you may have trouble finding something to fit it correctly.
