engine question
Discussion in '1960-1966' started by Glen, Apr 18, 2004.
  1. Glen
    Glen Member
    Tulsa
    I'm running a fairly stock 250 in my '63 c-20, with the original granny low 4 speed. With the 5.13 rearend I have plently of power at low speeds. I am using the truck to pull a 25 gooseneck trailer with two antique tractors on it. The trailer and tractors weighs around 10,000. I am asking too much of my little 250? I was driving about 60 mph on the expressway yesterday, (no trailer, just empty truck) and I shelled the Cam Shaft gear. It's been about 4 years and 50,000 miles since I overhauled the motor, and used the same camshaft and gear. Would I be better off finding a small block? Was the cam gear failure related to my excessive towing use? Anybody else out there working one of these 6 cylinders hard? Anyone else out there shelled the cam shaft gear and why? I am considering dropping a bone stock 350 in. I don't think it would be too hard. Just use CD's tubular motor mount and everything should bolt right up.
  2. tech1
    tech1 Member
    Sorry, but we don't carry a tubular crossmember for the 60-66 trucks. I hear that you can use the original motor mount perces you just have to change the location of one of them. I'm not for certain because I have not done this myself but I'm sure there is plenty of people out there that has made this switch over that can advise us of what it takes.
  3. rickster
    rickster Member
    Quinter USA
    I know this is WAY late, I have a 63 stepside and took the 230 6 banger out and installed a 350 from a 76 3/4 ton, I didn't use any new parts just the stock mtr mounts off the truck, worked great.
