slam'd 51 suburban with 350SBC - which trans?
Discussion in '1947-1954' started by sssingo, Oct 31, 2012.
  1. sssingo
    sssingo Member
    Airride 51 Chevy suburban
    Hiya Guys,
    I'm new here and am currently at the starts of a major ressurection of a 51 suburban with airride and a 350SBC.
    Just want to know what you think would be best trans to haul this lump around and that would allow me enough clearances without any deeper sumps or alike.
    I would like as many gears as poss or an overdrive
    As I see it, I've got:
    TH350C (but how deep is the extra sump needed to keep these cool)
    TH400
    700R4
    Any help would be appreciated. I believe there are shots on my gallery so you can see exactly how little clearance I'm dealing with
  2. ol' chebby
    700r. It will fit fine. THe frames on these trucks is tucked way up, so the chassis isn't as low as the body looks.
    I have a 700 in mine. OD is the only way to go.
  3. ccharr
    Welcome aboard, enjoy the ride while here.
  4. coilover
    You don't need a deep sump pan at all, even for heavy towing; just use a transmission cooler. The heavy duty "Tow Packages" on late model trucks have this with a stock pan. The cooler can be mounted anywhere up out of the way with it's own cooling fan if necessary but usually is in front of the radiator/ac condensor. Picking the correct size is good since too big a cooler in colder areas can keep the fluid too cool. Many don't realise an inside the radiator cooler also heats the fluid to good working temp in the winter.
  5. sssingo
    sssingo Member
    Thats good enough for me then. Cheers guys. We don't need to worry about getting too cool or too hot here in the UK - just too wet ;-)
    Is there anything else I need to be aware of with fitting etc of a 700R.
  6. ol' chebby
    May have to "message" the floor at the firewall, just like with a t 350. The crossmember is a few inches more rearward.....use a tubular one. Most trans shops will tell you that the lockup converters tend to be more problem than value, don't concern yourself too much with it. The later years are more desireable, better parts and strength. Mine is out of a 95 Suburban.
    350thc
    These fine lockup Slushboxes are found cheaply in 1980's Caddys , Buicks and even those old Chevy Impalas down to the local self service junkyard .
    Not as good as over drive but far less complicated and so cheap to repair on the odd occasion .
    A Lockheart by pass cooler and thermostatic valve is wise , never have to worry about cold ATF that way .
    Just go with the tranny you like , they're pretty much all good .
  8. sssingo
    sssingo Member
    700r4
    Great - thanks again for the heads up. Will let you know how I get on.
  9. 50 chevy 3100
    50 chevy 3100 Member
    i have air ride (lay frame) on m 50 pickup and she has a sbc with a 350t and is all good and tucked away nicely, i also have a beecool ally rad on her too, keeps her cool and running right
    hth
    Matt
  10. sssingo
    sssingo Member
    Cheers Matt. At that stage now
  11. Blueflame236
    Transmission
    Welcome aboard !
    I have just written a thread this week about installing the S10-T5 transmission with OD. if this is intresting have a peek. I know it fits the 350 chevy engine and people love it.What rearend cardan ratio does your car have?
    Greatings from Norway Martinius.
  12. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    Welcome to the forums. Looks like a pretty cool ride you have there. Looking forward to seeing more of it.
    Damon
  13. sssingo
    sssingo Member
    Its a donor rear end. We are going to get it up and running then see if the internals need swapping over. Cheers for comments guys
  14. sssingo
    sssingo Member
  15. sssingo
    sssingo Member
  16. sssingo
    sssingo Member
    350SBC Engine Installed
    Getting there. Just waiting for a front end bolt kit from Brothers truck before we can get her back together proper.
