new bed!
Discussion in '1947-1954' started by denisf, Nov 20, 2012.
  1. denisf
    denisf Member
    Colchester, CT/ Clermont, FL
    I have about an hour of work left on the new bed but I think it came out pretty good. Big project for this novice restorer. Thanks to those who provided advice.
  2. ol' chebby
    very nice!
  3. denisf
    denisf Member
    thanks
    The next project is to rewire the truck. I bough the e z wire kit and have printed out your blow by blow.
  4. ol' chebby
    It really is simple. Plan it out and install section by section. Take notes on anything custom you do or plan so you can always consult it.
    Call me if you hit any snags.
  5. denisf
    denisf Member
    Rewire
    Thanks good idea on notes. Probably pictures will help also. Glad I still play with trucks
  6. markcp
    markcp Member
    Southern Minnesota
    Great looking bed, thanks for the pictures
    Bed Rebuild
    Very nice indeed .
    No , go get some plywood to cover it in case you decide to use the truck for hauling...
    A note : unless you have many added things , the original , stock , $100 replacement harness works just fine , you don't need all those extra wires , a radio etc. is simple to add on .
  8. Zig
    That really turned out great, Denis! Absolutely beautiful!
  9. Blueflame236
    Nice work !
    Looks great Denis.
  10. Bilbo
    Bilbo Member
    Magnolia, Texas
    Very nice bed, Denis. What did you use to protect the wood? I'm not there yet, but looking at options.
  11. denisf
    denisf Member
    poly
    I used numerous coats of clear poly, I think the brand was valspar
  12. ol' chebby
    According to Mar Cal's testing, all clears will fail in weather, some faster than others- usually starting with the sharp corners.
    The Tung oil on the 53 has been in Florida for 2 years and is looking great.
  13. vwnate1
    Tung Oil !
    It's AMAZING stuff ! .
    Just be aware you need to wear gloves when applying it and toss out the brush or clean rags you use to apply it .
    Best of all , you can easily apply more in the years to come , keeping your wood sealed and looking nice .
