Exhaust Dumping
Discussion in '1955-1959' started by steve, Dec 16, 2012.
  1. steve
    steve Member
    Virginia
    Dumping Exhaust
    I guess it’s personal preference, or is it best to dump the exhaust behind the rear tires or straight out the back? Right now my dual 2.5 inch is dumped out the back (my first atempt). Now like behind the tires?
    I think there are some state laws indicating where the exhaust should be placed?
    This is my issue, that's why call them customs right.
  2. Lakeroadster
    Lakeroadster Member
    Central Colorado
    § 46.2-1049. Exhaust system in good working order.
    No person shall drive and no owner of a vehicle shall permit or allow the operation of any such vehicle on a highway unless it is equipped with an exhaust system in good working order and in constant operation to prevent excessive or unusual levels of noise; provided however, that for motor vehicles, such exhaust system shall be of a type installed as standard factory equipment, or comparable to that designed for use on the particular vehicle as standard factory equipment. An exhaust system shall not be deemed to prevent excessive or unusual noise if it permits the escape of noise in excess of that permitted by the standard factory equipment exhaust system of private passenger motor vehicles or trucks of standard make.
    The term "exhaust system," as used in this section, means all the parts of a vehicle through which the exhaust passes after leaving the engine block, including mufflers and other sound dissipative devices.
    Chambered pipes are not an effective muffling device to prevent excessive or unusual noise, and any vehicle equipped with chambered pipes shall be deemed in violation of this section.
    (Code 1950, § 46-305; 1952, c. 455; 1956, c. 651; 1958, c. 541, § 46.1-301; 1960, c. 120; 1970, c. 266; 1972, c. 66; 1989, c. 727; 2006, cc. 529, 538.)
    § 46.2-1049. (Effective October 1, 2012) Exhaust system in good working order.
    The provisions of this section shall not apply to converted electric vehicles.​
    § 46.2-1047. Muffler cutout, etc., illegal.
    It shall be unlawful to sell or offer for sale any (i) muffler without interior baffle plates or other effective muffling device or (ii) gutted muffler, muffler cutout, or straight exhaust. It shall be unlawful for any person to operate on the highways in the Commonwealth a motor vehicle, moped, or motorized skateboard or scooter equipped with a gutted muffler, muffler cutout, or straight exhaust​
    § 46.2-1000. Equipment
    Department to suspend registration of vehicles lacking certain equipment; officer to take possession of registration card, license plates and decals when observing defect in motor vehicle; when to be returned.
    The Department shall suspend the registration of any motor vehicle, trailer, or semitrailer which the Department or the Department of State Police determines is not equipped with proper (i) brakes, (ii) lights, (iii) horn or warning device, (iv) turn signals, (v) safety glass when required by law, (vi) mirror, (vii) muffler, (viii) windshield wiper, (ix) steering gear adequate to ensure the safe movement of the vehicle as required by this title or when such vehicle is equipped with a smoke screen device or cutout or when such motor vehicle, trailer, or semitrailer is otherwise unsafe to be operated.
    Any law-enforcement officer shall, when he observes any defect in a motor vehicle as described above, take possession of the registration card, license plates, and decals of any such vehicle and retain the same in his possession for a period of fifteen days unless the owner of the vehicle corrects the defects or obtains a new safety inspection sticker from an authorized safety inspection station. When the defect or defects are corrected as indicated above the registration card, license plates, and decals shall be returned to the owner. ​
  3. steve
    steve Member
    Virginia
    Laws, Laws did you say Laws!
    I was on my knees with my hands behind my head reading your response, I was having a teenage flashback!. Thanks for the info.
    Northern Virginia DMV Laws, states the following.
    (1972, c. 640, § 46.1-301.1; 1973, c. 5; 1989, c. 727.)
    § 46.2-1048. (Effective October 1, 2102) Pollution control systems or devices.
    No motor vehicle registered in the Commonwealth and manufactured for the model year 1973 or for subsequent model years shall be operated on the highways in the Commonwealth unless it is equipped with an air pollution control system, device, or combination of such systems or devices installed in accordance with federal laws and regulations.
    It shall be unlawful for any person to operate a motor vehicle, as herein described, on the highways in the Commonwealth with its pollution control system or device removed or otherwise rendered inoperable.
    It shall be unlawful for any person to operate on the highways in the Commonwealth a motor vehicle, as described in this section, equipped with any emission control system or device unless it is of a type installed as standard factory equipment, or comparable to that designed for use upon the particular vehicle as standard factory equipment.
    No motor vehicle, as described in this section, shall be issued a safety inspection approval sticker unless it is equipped as provided under the foregoing provisions of this section or if it violates this section.
    The provisions of this section shall not prohibit or prevent shop adjustments or replacements of equipment for maintenance or repair or the conversion of engines to low polluting fuels, such as, but not limited to, natural gas or propane, so long as such action does not degrade the antipollution capabilities of the vehicle power system.
    I don't like loud, and sinde the stock exited out the rear It will remain out the rear.
    Exhaust
    In truth , it all boils down to how much you want to annoy everyone else ~
    Long pipes out the back are mellower regardless of anything else .
    Adding , say , ' fart can ' muflers or those extremely noisy turbo mufflers can raise it back up to nasty levels but I rarely have any mufflers atall , I do use crossovers to improve scavanging but the end noise , isn't terrible unless I romp on it really hard .
    You pays your moneys and makes your choice .
  5. VELCRO
    VELCRO Member
    OCALA USA
    exhaust
    Florida law is fairly liberal on exhaust systems. Basically, the system has to be in good working order with no leaks and no excessive or unusual noise. The decible level is set by D.O.T.
    My truck has a built 350 with after market headers and dual exhaust that was built by a local exhaust shop. The mufflers I chose are not loud because I like hearing the truck noise as I drive so I can keep tabs on everything.
    Probably a good idea to check with the laws of the state you are in.
    One thing I realized as I was building my truck, you only have to please one person, so please youself.
    Gerald in Florida
    truckin is good for you
