Fender from Bethlehelm
Discussion in '1947-1954' started by denisf, Dec 22, 2012.
  1. denisf
    denisf Member
    Colchester, CT/ Clermont, FL
    Well I have been to Bethlehem today,of course the one in Connecticut.
    I went there to buy a fender for my truck to learn to do body work.
    Well as you can see I will get to learn a lot. Got it for $30. I am sure this piece will let me learn many aspects of metal work; tin knocking, welding, even some simple fabrication; and then prep and paint.
    The guy had a yard and house full car parts, pretty amazing place/person.
    I am open to any feedback / advice on how best to approach this learning project.
  2. ol' chebby
    Get it sandblasted first, so you can see what all is needed.
  3. denisf
    denisf Member
    good idea
    I have a small blaster, so I will do that.
  4. Mike1951
    Mike1951 Member
    Osawatomie, KS
    Small blaster
    I did my whole truck with a 40 lb pot sand blaster I bought from Harbor Freight for cheap. Took a while but you can do it. Start on the inside and get a feel for it if you haven't run the blaster much.
    Merry Christmas
    Papy
  5. denisf
    denisf Member
    sandblast
    Thanks Mike, good tip on starting on the inside. I think the one I got came from Eastwood. I need to think through where to do it as to not make too big of a mess. Bit looking forward to working on the fender and learning.
    Life is good. Happy Holidays!
    Blasting Rusty Bits
    It's not overly difficult to set up an " Easy Up " typ of tent thing using cheap tubing and clear plastic , this keeps the dust and mess down , you really should run a face mask with external air supply should as silicosis is a nasty death .
    Also , use glass beads not sand , sand is extremely abrasive and heats up the metal and causes warping much easier than does glass beads .
    Take your time here , test it out on other le$$ valuable bit first , you'll really like media blasting once you get dialed in to it .
    Never , EVER blast anything that goes into the engine ! :eek: rods , valve covers , oil pans , steel timing gears etc. - don't do it ! .
  7. denisf
    denisf Member
  8. denisf
    denisf Member
    media
    Eastwood sells a glass media that says, "70-100-grit size" but the shipping cost is outrageous.
  9. Mike1951
    Mike1951 Member
    Osawatomie, KS
    Coal slag
    Nate is right on sand. Don't do it. Silicosis of the lungs is nothing to fool with. I used fine coal slag. It's hard,cuts rust, does not shatter (causing excess dust?)and it sells around here for 15 buck a 100lb bag. I had to sweep it up and I'm cheap so I screened it through an old window screen and reused it. Glass is probably better if you can find but the slag will work. I started 9 years ago in the basement shop and I'm still sweeping up coal slag the tent sounds like a lot better idea!
    Papy
  10. denisf
    denisf Member
  11. Mike1951
    Mike1951 Member
    Osawatomie, KS
    Black Beauty
    Black Beauty is coal slag from Reed Mineral. That's what I have and am using. It's pretty safe no free silica you still need a good mask as plenty of dirt and rust will get airborne. Find an old window screen and sieve out the large pieces and keep using it until its powder. Good luck
    Papy
  12. denisf
    denisf Member
    thanks
    Good tips thanks.
  13. Bilbo
    Bilbo Member
    Magnolia, Texas
    Hey Denis. I've used the Black Beauty, and an 80# Harbor Freight tank, to do my entire project thus far. Paying about $8.00/ 50# bag, (they're easier to handle.) No warping. I set up an outside area using plastic tarps, including the floor, to make easier clean-up for re-use. It's working well. So far, I've used about 800lb of media. I expect to need only about another 150 to 200lb. I reuse most, and make up with new to help with the effectiveness. Sounds like you're on the right track with your plan.:)
  14. denisf
    denisf Member
    black beauty it is
    Thanks I appreciate all the thoughts.
