1962 235 front motor mount
Discussion in '1960-1966' started by dado, Mar 8, 2010.
  1. dado
    dado Member
    Bogart
    Who sells it any body got a part #:D
  2. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
  3. dado
    dado Member
    Bogart
  4. dado
    dado Member
    Bogart
    Re 235 mount
    Well as it turns out these mounts are exclusive to this truck 60-62 discontinued sometime ago :eek:I will find one & I will post part #along with supplier. Hey big Tim can we get a good look at that motor in your profile pic is that what I think it is ?
  5. joek3167
    joek3167 Member
    There is 1 on e-bay right now nos
  6. bigtimjamestown
    Jamestown Ca.
    Hey big Tim can we get a good look at that motor in your profile pic is that what I think it is ?[/QUOTE] Why yes , yes it is and thanks for noticing......It's a
    261 Chevy .030 over with 9.5-1 Jans pistons .125 shaved off the head with resesed valves, porting and .08 decked off the top of the block with head studs installed. The center weight was chopped of the crank and the crank was balanced Custom 4 bolt main caps were made and the rods were shot peen and I beam ground with ARP rod bolts installed. A custom Crowler cam shaft was made and Clifford made an Alum. fly wheel. A custom tunnel ram was made by me as well as a set of S.S. fender well headers. Two Holly 350 CFM Carbs with 50 CC accelerator pumps, Mallory (YC) type distributor, Mallory coil, and Accel 8.8 mm wires were used with an MSD 6A ignition box with timing control. Borg Warner super T 10 4 SPD. with a vertical gate shifter, narrowed 9 In., Strange billet carrier, Detroit Locker with 456 gears. All machine work was done by Bell & Gains Service and assembled by Larry Neville of Neville Bros. Automotive Modesto Ca. and myself This thing will smoke them 31x18.50x15 Micky's through 2 gears, rip 3Rd. and bark 4TH OH YEAH...:cool: tims pics 026.jpg
  7. hamrs_62
    hamrs_62 Member
    empire, ca.
    very nice,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, since you live up there you know, dan m. who lives up rawhide, he's a racer
    261 Chevy .030 over with 9.5-1 Jans pistons .125 shaved off the head with resesed valves, porting and .08 decked off the top of the block with head studs installed. The center weight was chopped of the crank and the crank was balanced Custom 4 bolt main caps were made and the rods were shot peen and I beam ground with ARP rod bolts installed. A custom Crowler cam shaft was made and Clifford made an Alum. fly wheel. A custom tunnel ram was made by me as well as a set of S.S. fender well headers. Two Holly 350 CFM Carbs with 50 CC accelerator pumps, Mallory (YC) type distributor, Mallory coil, and Accel 8.8 mm wires were used with an MSD 6A ignition box with timing control. Borg Warner super T 10 4 SPD. with a vertical gate shifter, narrowed 9 In., Strange billet carrier, Detroit Locker with 456 gears. All machine work was done by Bell & Gains Service and assembled by Larry Neville of Neville Bros. Automotive Modesto Ca. and myself This thing will smoke them 31x18.50x15 Micky's through 2 gears, rip 3Rd. and bark 4TH OH YEAH...:cool: View attachment 5280
    View attachment 5281 [/QUOTE]
  8. bigtimjamestown
    Jamestown Ca.
    Hamrs, yeah I'm pretty sure I know him. Doesn't he have a Falcon pickup and a old rat rod he's building?
  9. hamrs_62
    hamrs_62 Member
    empire, ca.
    dont know what he is building, he has a fueler he drive for a guy, races around, sac, and where ever, he has a son named toby who wrenches with him, his son still works with me, he just retired
  10. dado
    dado Member
    Bogart
    I thought that is what I saw .
    Like I tell my kids always pay attention . You never know what you may see thanks for sharing looks REALLY REALLY great .
  11. dado
    dado Member
    Bogart
    The elusive mount
    Well here is a photo. This mount is exclusive to the '60-'62 with a 235. This is the only year this mount was used. It has been discontinued for quite some time. No one has it. If you have one, put it on Fleabay, and you will make big bucks. I think I found one in a dealership; we'll know when it gets here.
  12. colettesbro
    colettesbro Member
    Owatonna, MN contact info: cell 507.456.3625 email
    235 front motor mounts available
    If anyone is looking for these 235 front mounts, I have a few available from trucks I have parted out.
    Thanks,
    Brian
    cell 507.456.3625
  13. dvalentine
    dvalentine Charter Member
    Sacramento
    It's a beautiful thing ............
    dv
  14. dado
    dado Member
    Bogart
    62 Mount up date
    Well the local parts guy at the Gmc dealership found a new one on the shelf in Pa. Cost me less than 21 american including shipping . One more pebble in the bucket !!:D
  15. smedli01
    smedli01 Member
    I have a 1962 chevy truck with a 235 (V6) with a 3 speed trans. I want to swap it out with a 283 (V8) but I can't find a bellhousing with hydraulic hook-up on the passenger side. Does anyone know what the GM part # I need is?? I have been searching and found tons of information, but can't find anyone who sells that type of bellhousing.
  16. bennythebull
    bennythebull Member
    catlett,Va
    Do you have the part number. I'm in need of finding one also . everyone is saying that there is four parts to it but mine looks like that picture and only has the rubber part.
