What is this?
Discussion in '1947-1954' started by Crane, Mar 12, 2013.
  1. Crane
    Crane Member
    Denver, colorado
    Possibly a pump/ coolant circulator? Has a 110 plug. Necessary or add on?
  2. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Block heater? Warm anti-freeze passively "rises"...
  3. Blueflame236
    Coolant water heater !
    Yes that looks like a coolant heater wich is offcourse an ad on. Truck might have been used in colder areas. Can you see what brand it is , some closeup pictures please !
    Martinius.
  4. Crane
    Crane Member
    Denver, colorado
    kinda what i thought. may bypass it for now and clean it up before next winter hits. would a modern block heater be abit more efficent?
    Coolant Heaters
    This one will prolly use le$$ electrical current....
    Having that extension cord too hot to touch isn't a good thing .
    I prefer coolant heaters to oil pan heaters .
    Freeze plug coolant heaters about but often begin weeping coolant in a few years .
    Best of all is the fast heater out put inn the winter plus , smoother running and less choke means le$$ fuel used / wasted....
