power steering wonder
Discussion in '1947-1954' started by Volker, Mar 21, 2013.
  1. Volker
    Volker Member
    Germany, nearby Leipzig
    After long time i come back to my garage and restarted with my F*** project.
    Mounted a power steering rack from a Chevy Chevette 1980 (rebuild an from www.carsteering.com ) on my Chevette Front end (connected on a F*** 1936). connect all hoses from the power pump, filled with fluid and bleeded.
    Now the wonder:
    If i turn a little bit on my steering wheel the steering turns full left then full right then full left .... till the engine is off.
    Have anyone an idea what's wrong with it??
    Volker
  2. Zig
    It's connected to a F$%#! Other than that, I got nothing. If you live in a mountainous area, I could see where this might be good.
    Now does this happen sitting still, or under power?
  3. Volker
    Volker Member
    car standing in my garage, all wheels are off the ground
  4. coilover
    The hoses are on backward. Reverse the pressure hose and the return hose.
    P.S. ' Drift '
    Back in the day , this meant the boob who'd just overhauled the steering box had put the Spool Valve in wrong .
    I bet your Chevette steering rack doesn't even have one of those .
  6. Volker
    Volker Member
    work's
    swapped the hoses and it work's. not so good as by my chevy but what you says it's a F*** :D
  7. Bilbo
    Bilbo Member
    Magnolia, Texas
    Yet another problem solved by the Vast Technical Knowledge Base of the Classic Parts Forum. :D
  8. 2click
    2click Member
    Deep southern Arizona
    Anyone know if the ABS direct fit power steering kit (#577) mounts on the inside or the outside of the frame rail?
  9. ccharr
    Welcome aboard, enjoy the ride while here. Do not know about the Question, where in southern Az are you, Nogales?
