Torque tube fill plug
Discussion in '1947-1954' started by Thunder54, Apr 7, 2013.
  1. Thunder54
    Thunder54 Member
    Port Arthur, TX
    What type of material can be used to seal the fill plug in a torque tube rear end?
    Will an "O" ring work or is a brass flat washer needed?
    Please advise.
    Jim
  2. jackson
    jackson Member
    Gold Bar, Wa.
    Is it leaking at the threads? Have you tried teflon tape?
  3. Blueflame236
    Material fill plug!
    Hamp or teflon tape is suitable !
    I assume you're talking about the fill plug for the banjo ? . it takes a fiber gasket , hard to find these days .
    I'd think a thin O-Ring would work , you might have to experiment with the cross section size a bit to find one that doesn't moosh out when tight .
  5. Thunder54
    Thunder54 Member
    Port Arthur, TX
    Banjo
    I need to read this site more often so I understand all the reference lingo.
    I put an "O" ring in the bung on my banjo!
    This works, but I do believe teflon thread tape is a good method as well.
    No leaks, I will watch it closely.
    thanks To each of you for responding.
    Jim
