Steering column and seat
Discussion in '1960-1966' started by chadg1271, May 31, 2006.
  1. chadg1271
    chadg1271 Member
    Wanting to upgrad my steering column in my 1966 c10 to one with tilt and power steering. Any idea on what year trucks to get one from, also looking for a bench seat to go in it, thanks
  2. dvalentine
    dvalentine Charter Member
    Sacramento
    [updated:LAST EDITED ON Jun-01-06 AT 11:52 AM (CST)]Before my last swap I used a 70's Van tilt column. It fit perfect and does not have the ignition mounted on the column. I switched to a Billet Specialties column last year.
    For a bench seat you have a ton of choices. Virtually ALL Chevy pickup seats from the 60's thru the 2000's will fit with only a few holes needed to be drilled. I initially had a late 70's 60/40 split bench but upgraded to a mid-90's split bench earlier this year.
    http://home.comcast.net/~dennisvalentine/wsb/media/446492/site1081.jpg
    For power steering, there is only ONE way of doing that safely, with a REZ Engineering steering box adapter.
    http://www.customclassictrucks.com/techarticles/84378/
    DVal
  3. chadg1271
    chadg1271 Member
    Thanks alot, wasn't sure about the seat, the orginal one is shot, thanks for your help.
