I have a 350, in a 64 C10, that I believe to be manufactured some time in the seventies or eighties. what is the correct timing and exactly where on the engine can I find out how old it is? Mike
RE: Whats the correct timing for a Mike, On most stock 350's the timing should be fine at 6-8 degree's before top dead center. If the cam is not stock you should contact the cam's manufacturer for the best timing suitable for your cam. DVal
RE: Whats the correct timing for a as for knowing the year of the block look behing the head on the left side ( driver's side ) on the flange where your bell housing bolts up and there will be a long number casted into the block , you get that number i'll be more than happy to run it for you Jesse Hazell Chevy Duty Tech.
