TPI Surging
Discussion in '1947-1954' started by mobileortho, May 29, 2013.
  1. mobileortho
    mobileortho Member
    Hampton, VA
    I'm running a TPI setup on my truck, noticed that at stop signs or lights the engine surges. It gets so bad at times I have to struggle to keep the brakes depressed to keep it from launching into on coming traffic. Any ideas what's going on? :confused:
  2. ccharr
    The Basics !
    First thing , replace the fuel filter , then you might try adjusting the TPS .
    I used to work on older F.I. systems and this was a problem back then too .
  4. Zig
    Robert, like it or not, you have a HOT ROD pickup! What, you expect it to wait patiently for the light to turn green??? You built that monster, now you'll have to deal with it! ;)
  5. mobileortho
    mobileortho Member
    Hampton, VA
    Adjusted the IAC, problem solved.
    Zig, too funny bro!
    "iac "
    Idle
    Air
    Control ? .
  7. mobileortho
    mobileortho Member
    Hampton, VA
    My bad
    Meant to say the TPS.
