max operating temp 235
Discussion in '1947-1954' started by jnycnuk, May 29, 2013.
  1. jnycnuk
    jnycnuk Member
    my 52 - 235 is running about 210 (according to the original gauge). a little hot isn't it?
  2. Blueflame236
    Max water temp
    180 F is normal working temp.210 F is to high!
    Martinius.
    Operating Temp.
    yes it is ~
    It won't hurt it as long as it gets no hotter but there's little margin for error there .
    Have you peered into the radiator when it's running ? . there should be a goodly current of coolant going past , the color is important too ~ if it's not translucent there's rust or crud in it that will hinder it's ability to transfer heat away .
    Dollar Stores usually have Candy or Turkey Thermometers with a long probe , place this in the open radiator neck when hot to see what the real coolant temp . is .
    Have you tested the radiator for clogs ? easy to do @ home .
    Easy to clean 'em out too , better than the Radiator Shop does .
  4. jnycnuk
    jnycnuk Member
    thanks guys. I think I will pick up a thermometer as suggested. I did find out the thermostat was a 195f. changed to 180f. I didn't see a lot of movement inside the rad but water does flow through from rad cap to bottom rad hose opening ok. I don't think the original temp gauge is 100 percent accurate but i' m glad it was there to warn me. it is running a bit cooler now.
