Exhaust Mainfold help
Discussion in '1955-1959' started by achansen22, Jun 7, 2013.
  1. achansen22
    achansen22 Member
    Any advice on replacing exhaust intake manifold or drilling out frozen bolts..I have been soaking broken off bolts w/penetrating juice. no joy
    thanks...andy
  2. AZ58Cameo
    AZ58Cameo Member
    Payson Arizona
    Can you get at them with an Impact wrench if so try to tighten a little then loosen
    FWIW
    Allen
  3. achansen22
    achansen22 Member
    no, I broke heads off I got manifold on bench. put pipe wrench to protruding stud and if I break whats left, I figure I will try to drill out and replace with hard bolt..sound right?
    thanks..andy
  4. AZ58Cameo
    AZ58Cameo Member
    Payson Arizona
    Yea, you could drill out and maybe re-tap the threads! just a thought could you apply
    heat from a torch to the studs? get the stud glowing red then let it cool down before
    you use the pipe wrench! Just a thought!
    Good Luck!
    Allen
  5. achansen22
    achansen22 Member
    I will give that a try tomorrow..
    thanks
  6. ccharr
    If you have a welder, weld a nut back on it and then use the impact wrench.
    Charles
  7. steve
    steve Member
    Virginia
    Little HEAT
    I grind a groove for a screwdriver or used channel locks if there is something to grab, and some heat. If you drill start with a smaller size bit (new good quality bit) good luck. been there....
  8. achansen22
    achansen22 Member
    thanks,,i will let you all know how it works out...
    andy
    Broken Stud
    I assume it's the collector stud you're struggling with ? .
    Wire brush it very well then find the biggest flat washer you can with the correct size hole , slip that over the old stud stub and weld a nut to the stud , once cooled , use the gas torch to heat up the stud & nut white hot then rapidly quench it with the garden hose ~ the rapid contraction of the white hot stud will cause it to shrink & break the threads loose .
    The flat washer ensures you don't overheat the manifold proper and prevents the torch's flame from heating the manifold flange at the same time you're super heating the stud .
    Remember to run a Tap in the hole before installing the new stud and never , EVER use a bolt in the exhaust manifold flange .
    The slower and more carefully you approach this repair ,the easier and better it will go .
    If this is for a V-8 , new Ram's Horn exhaust manifolds are available from ATP
  10. achansen22
    achansen22 Member
    what is the problem with using a hard bolt from exhaust flange to manifold?
    andy
  11. vwnate1
    It'l loosen up with the normal thermal cycles and leak .
