engine ID
Discussion in '1947-1954' started by SkeeterBilt, Jul 4, 2013.
  1. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    wanted to start a new thread on this
    as some know im dealin with my engine and im tryin to figure out what i have, a 216 or a 235 and since its deff blue and hasnt been repainted by a young stupid youth, vwnate.
    so my engine code is AHCA965II9
    and this website im using doesnt have any info to help
    http://chevy.oldcarmanualproject.com/models/engine.htm
    anyone wanna help? thanks
    its in a 1950 3/4 ton floor shift
  2. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    i think i figured it out
    AHCM ** Tonawanda 6 235ci
    ** "A" will precede prefix if motor is used on a 3600 and 3800 series.
    so AHCA is from Tonawanda plant and 6cylinder and i have a 235... right
  3. Blueflame236
  4. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    I'm no expert, but the full-height push rod cover appears to be from a 216.
    Damon
  5. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    yea this is hard. goin off that website and my ID its a 235 since its in a 3/4 ton, but the valve cover looks like a 216
  6. ccharr
  7. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    thank you. they are all good reading but i still have more questions than answers... from what im gettin i have an early 235 with the 2 stud valve cover. but i dont understand the "pushrod cover extends from the valve cover, past the spark plugs and ends near the base of the distributor." part
  8. Blueflame236
    Pistons measure !
    The pistons measure will tell you how big it really is.
    Martinius.
  9. ol' chebby
    What kind of oil pressure do you have? Does it peg a 0-30 guage? or do you have a 0-60?
  10. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    ill look, i know that will help. thanks bud
  11. Blueflame236
    pressure
    The gauges can be reinstalled later to give more accurate water/oil pressure indications but as far as i know a lot a trucks 3100 /3600/3800 also used a 0-30 gauges depending on what year they came and engine they used. 0-60 gauge for the 235 is correct!
    Take a look at the waterpump.The 235 has a long shaft water pump and the 216 a short shaft one.There mounted in the same location.
    216 CU pump EBAY link; http://www.ebay.com/bhp/chevy-216-water-pump
    235 pump & pully photo.
    Martinius.
  12. DeadZoneTruckin
    DeadZoneTruckin Member
    That is a 216 for sure {could also be an early 235 splash engine}.
    Anyway ya cut it .... it is a pre-1954 babbitt pounder.
    The only sure way to decode the engine is to get the numbers & letters that are cast into the block right behind the starter..... post up that info. & I can decode it i my head.
  13. Blueflame236
    216 it is
    216 CU 1950 Flint AHCA series engine
  14. vwnate1
    Oops
    Sorry for running my mouth before I have coffee or get my alleged brain in gear .
    As Joe mentioned , you have there a Chevrolet ' Babbit Pounder ' engine so in the end it makes no difference , you tune both the 216 & 235 variants the same and cannot run them overly fast without tossing the rods and destroying it .
  15. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    hmmm good info guys. thanks
    i just dont know what to do with this motor problem. i can throw a v8 in it and hopefully have a reliable runnin truck. but thats easier said than done.
  16. ccharr
    That link is spooky, my first wife did that and I had a G at the time also.
    http://oi43.tinypic.com/2yphkwp.jpg
  17. DeadZoneTruckin
    I think she's kinda sexy when she's mad :D
