Head Liner??
Discussion in '1947-1954' started by SkeeterBilt, Jul 22, 2013.
  1. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
  2. ol' chebby
  3. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    I wondered the same as well, because they were so inexpensive. Should have known 'ol Chebby had a write-up on this as well... :D
  4. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    well he does have some sweet rides and awesome write ups
  5. DeadZoneTruckin
    DeadZoneTruckin Member
  6. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    good to know
  7. oldbluetruck
    oldbluetruck Member
    SoCal
    My back panel droops in my 48 3100
  8. ol' chebby
    Damn near impossible to get one to lay flat with no crinkles and to cover all the gaps. I vote the one piece also.
  9. ccharr
    Like Button on the one piece.
  10. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    one piecer it it. thanks
  11. Zig
    I couldn't begin to imagine how pissed I would be if I had spent the time and effort to get a cardboard headliner in, only to see it pucker and buckle like the door panels did. It cost much more, but I love the options the one piece gives of painting or even covering it with material. And it will never be a problem again~
  12. bmacdona
    bmacdona Member
    I looked at the one piece headliners when I was replacing the cardboard liner and just couldn't justify the price.
    As an alternative, I picked up a sheet of FRP (fiberglass reinforced plastic) from Lowes for about $45 and used the cardboard headliner as a template. It's available in black, white or beige and while I haven't painted it, you should be able to if you need to match an interior color other than the standard.
    I was able to cut it using a sabre saw and the only difficulty in fitting it was the sharp bend over the doors. I ended up using a heat gun to soften it a bit and it turned out fine. I don't have pictures of the headliner portion, but here's a pic of the door panel and a cover of the seat base, of the same material.
    Just an idea.
      File size:
      53.3 KB
      450
  13. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    thats a good idea.
  14. coilover
    I used the cardboard crap---once. A sparrow peed on the top and that let enough moisture drift into the cab to make the two sections droop like runway windsocks on a calm day.
  15. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    like button
