Question on Carter W-1
Discussion in '1947-1954' started by markcp, Sep 12, 2013.
  1. markcp
    markcp Member
    Southern Minnesota
    My 49 with the Carter W-1 recently needed the soggy carb float replaced.
    I have a question on the attached picture. The brass washer that sits over the needle looks out of place on the top of the carb plate. I see no other location for this washer though. Does anyone have an exploded diagram of the W-1 and where this washer goes?
    Thank you for the help,
    Mark
    W-1 Assembly Question
    I'm sure someone here has the instruction sheet from a carby rebuild kit , perhaps they could scan and post it here ? .
    That's what Mark needs most .
  3. DeadZoneTruckin
    DeadZoneTruckin Member
  4. markcp
    markcp Member
    Southern Minnesota
    Thanks guys for the help.
