1948 GMC 3 speed column shift box problem
Discussion in '1947-1954' started by 48gmc, Nov 10, 2013.
  1. 48gmc
    48gmc Member
    Tucson Arizona
    Thanks for membership. I have a 1948 GMC panel truck. The other day I went to shift into 2nd gear, and the shifter went limp. No 2nd or 3rd gear. 1st and reverse are OK.
    The lever does not move in order to push the linkage arm. I am not seeing any broken steel or loose parts anywhere in the gear cup. The transmission is OK, I can move the lever manually to engage the gears. I even start the truck in 2nd and 3rd gear just to make sure. They're fine.
    I've had this truck for 25 years, this is the first time I've encountered this.
    Anyone ever had this happen?
    YouTube video below showing what's happening
    Thanks in advance
    https://www.youtube.com/watch?v=El5A72qEGJI
  2. DeadZoneTruckin
    DeadZoneTruckin Member
    After our conversations yesterday... you got me stumped also Ray... but it looks like the shifter fork in the box is stripped on the shaft.
  3. coralhead
    coralhead Member
    S Indiana
    Not sure how that fork is attached but agree w/Joe on that. The fork may have sheared a few small welds on the bushing that actuates the shift rod lever. May look at how the 1st/R fork is attached to its shift arm. May just have to disassemble the rest of the way and have it rewelded or clean it up from the grease, make sure you are in N and put a small tack weld between the shift for and the bushing to tie the two back together and then try it. My .04 worth from looking at the video.
  4. 48gmc
    48gmc Member
    Tucson Arizona
    Took the lever off and found a thin brass bushing that was ground down on the shaft itself. Apparently these were pressed on, and the 'fork' just came loose.
    Going to have it welded tomorrow. Thanks guys.
  5. coralhead
    coralhead Member
    S Indiana
    make sure the fork is clocked to the arm (anglewise) before you have it welded. Glad it can be repaired.
  6. RustyDog
    RustyDog Member
    Lakeland, Fl
    I am surprised that these guys gave you some advice without asking for pictures. I was under the impression that pictures were a requirement, if not mandatory.
    Would love to see your 48. Mine is going to get blasted next week. Then the real work begins...
  7. ol' chebby
    They ARE a requirement.......we all like to look at the pitchers.....
    The 41 F**d is being blasted now.
    Refer to the thread at the top of the forum regularly after the blasting!
  8. 48gmc
    48gmc Member
    Tucson Arizona
    Did you not see my video link..?
  9. DeadZoneTruckin
    ...........:rolleyes:
  10. 48gmc
    48gmc Member
    Tucson Arizona
    Update:
    Had the lever and fork welded today, and it all works fine now.
    Thanks coralhead and Joe!
  11. coralhead
    coralhead Member
    S Indiana
    I'm a mechanical engineer and spend my days troubleshooting electronic connector assembly machines. I like the moving pitchers. Glad to be of help.
  12. ccharr
    Welcome aboard enjoy the ride while here. Got any photos beside the wheel from your moniker?
  13. DeadZoneTruckin
    Here is Rays Truck :D
    https://www.youtube.com/watch?v=iguUFL-YWFc
    Everyone in Tucson knows it as the panel van with the barbed wire rear windows .:D
  14. ccharr
    Thanks Joe,
    That is a Great looking Panel, I really like the looks of it.
  15. coralhead
    coralhead Member
    S Indiana
    Same here........
