Aftermarket Radiator where to buy
Discussion in '1947-1954' started by Ricos54, Dec 3, 2013.
  1. Ricos54
    Ricos54 Member
    CA
    I just bought a crate 350 with a 700R4 tranny and a transmission shop in town told me I should get a radiator for a automatic transmission that can support my engine and trans together. Just wondering if anyone has bought an aftermarket radiator like this and where they bought it.
  2. AZbent
    AZbent Member
    Gilbert, AZ
    I would not use a radiator with the internal trans cooler. The trans fluid will never be cooler than the engine coolant. If your engine runs hot, then your trans fluid will be hot. I don't remember the numbers, but for every 5 degrees over a certain temp (220 is what comes to mind) the trans will lose a percentage of its life. The hotter it gets, the quicker it goes down hill. So, get a separate trans cooler for peace of mind. Some people will argue my point, but that is my opinion.
  3. ol' chebby
    I use and reccommend Champion radiators from Ebay (pretty much what everyone sells). The ONLY issue I have had is the threads pulling out of the trans cooler hookup after repeated installations/removals. I use a thread adapter that piggybacks the hard line. Screw the adapter into the radiator and leave it. You can then thread/unthread all you need.
    I find them for $170 shipped all day. You only need a 2 core as aluminum exchanges heat quicker. I also like the Black Magic fans from Summit....they are expensive but they move 3300CFMs.
  4. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Walker Radiator Works
    Walker Radiator Works: http://www.walkerradiatorworks.com/index.cfm
    The Most Respected Name in Quality Cooling Systems
    Established in 1932
    Specializing in Coolant and Air management packages for the Street Rod and High Performance Automotive field, Walker Radiator Works is recognized as the world leader in cooling system packages.
    With over 85% market share in the Street Rod Market, we take pride in our quality controlled manufacturing process and same day shipping policy.
    Home of the all Copper/Brass Radiator, our 10-year warranty is unsurpassed by any other.
    Radiators
    Walker is good .
    I've also used U.S. Radiator in Los Angeles to good effect , American made , OEM or better quality .
    Me , I always go for at least THREE row cores and let the thermostat do the work .
    External tranny coolers are iffy ~ the in radiator tranny cooler is smart because if warms up the ATF , few realize than too cold ATF wears out the tranny fast to .
    Best is to use two coolers and run a thermostat .
    Avoid Chinese shyte at all costs .
