Disc brake conversion
Discussion in '1960-1966' started by pearldrumbum, Oct 20, 2005.
  1. pearldrumbum
    pearldrumbum Member
    Kent, WA
    [updated:LAST EDITED ON Oct-20-05 AT 03:48 PM (CST)]Is it true that a 73-77 front end with disc brakes will bolt right into my '60?
    also, did any of these years have 6 lug wheels? Because i really don't wanna have to buy new wheels or use an adaptor.
  2. drabo
    drabo Member
    Patrick AFB, Florida
    I'm not sure if it will bolt right up but it should fit. You might have to drill a few holes. You can buy 6 lug rotors from ccp and chevy duty that fit right on those spindles.
  3. TxTradman
    TxTradman Member
    Paris USA
    I just used everything( from a 78) BUT the crossmember on my 66, I made the mistake of switching everything to 5 lug, i would advise against that. You can find alot more wheels for 6 lug than you can 5. I put the oversize brakes on mine and the 15" won't go over the calipers. NOW< Try finding used 17" or bigger 5 lug, I still haven't at a resonable price yet. But it's a 2 year project that i'm doing, so no real rush. Anyhow, hop ethis helps
