Volt Meter Gauge
Discussion in '1960-1966' started by Dougs55, Jan 13, 2014.
  1. Dougs55
    Dougs55 Member
    Didn't take me long to get back to asking questions!
    I have hooked up everything that I am aware of to get a signal back to my volt meter in the dash but I am missing something. I have included a sketch to kind of show what I have but not sure how the signal gets back to gauge. The fusable link has me confused as well and do not know where to put it, I am sure I can pick one up at the parts store.
    Help:confused:
  2. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Are you using a volt meter or amp gauge...? Volt meter is tied into any switched circut ( with ignition switch on ) and a ground.
  3. Dougs55
    Dougs55 Member
    It's a volt meter and yes that is what I thought and I had it tied into a hot wire but not at the ignition. Guess I will try that and see if that will solve the problem.
    Volt Meter
    You can tie it in anywhere there's switched 12 volts .
    Remember to wire the radio live so you can listen to it with the key off .
  5. 66 Truck Drive
    66 Truck Drive Member
    Next to my bench at the shop, Oregon
    Come to think of it....the radio is gone in my truck. LOL! :D
  6. Dougs55
    Dougs55 Member
    Voltage Gauge
    Finally got it through my thick head that the thing was bad. Ordered a new one and all is good on the home front. It is on to the brake glitch that I need to figure out.
