Rear Bumper, model 3804 Chevy 1947 thru 54
Discussion in '1947-1954' started by 1951chevy1ton, Jan 21, 2014.
  1. 1951chevy1ton
    1951chevy1ton Member
    Near Sleepy Eye MN
    Does anyone have any plans or pictures of their rear bumper set up which would incorporate a receiver hitch on a 1 ton. I just smashed beyond recognition one of the tin foil foreign versions out there. I am thinking diamond plate wrap around design that could be used for something besides looking at. I do not store my spare under bed. Thanks, Jerry
  2. ol' chebby
    You should have seen the big redneck farmall bumper that was on mine when I got it. Looked like 2 step bumpers welded on top of each other, then welded to the frame. 2 outriggers went from the bottom to the frame. They used to pull polo horses in a triler with it. An f 150 rear ended me with it,,,,,,folded his bumper, didn't scratch mine. I used it to patch my fence bottom for years, finally scrapped it.
  3. RustyDog
    RustyDog Member
    Lakeland, Fl
    Here are a few of my 1 ton. This hitch is a standard hitch that they simply added brackets to mount it below the bumper, but it looks like a beast. You should have heard the tow truck guy cursing it:)
    I can get more if you need them.
  4. 1951chevy1ton
    Near Sleepy Eye MN
    Pictures
    Pictures showing the mounting of that receiver to the frame would be great and I thank you in advance. Jerry
  5. coilover
    Here is one on a 48 3100 but the principle would be the same. IIRC the bracket is for a 48-72 Ford PU and was the right width to bolt to the bottom frame flanges and then braced to the old spare tire crossmember. The hitch is concealed behind the license plate so when he uses it he puts the license in the back window and slides the hitch into the receiver. The I.D. light even lights up the ball for hooking up in the dark. For ones looking that is a factory under bed gas tank and the Panhard bar is near level when the weight of the bed is on the chassis.
    Rear Bumper
    If you're going to tow with it , use a diamond plate AD truck bumper properly mounted .
    Most of the time folks remove and discard them so there's plenty to be found , you just have to begin beating the bushes , asking every single AD Hot Rod owner what they did with the nasty old heavy , FUGLY bumper .
    They're easy to straighten out and then bead blast , have painted or powder coated then install and you'll have a unique tow rig that looks good as well as SAFE and gives better crash protection too .
  7. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    Nate -
    Do you happen to have a photo of the optional diamond plate AD towing bumper?
    Damon
    Rear Bumpers
    No ;
    So many different ones were made and sold , there's no way to catalog them all .
    Joe will have some stacked up ready to sell as few seem to want them , I won't have a pickup without one .
  9. 1951chevy1ton
    Near Sleepy Eye MN
    Joe, What you got?
    Stacked up out there regarding this style?
  10. RustyDog
    RustyDog Member
    Lakeland, Fl
    Finally had time to get some pics.
      File size:
      39.7 KB
      239
      File size:
      42 KB
      237
      File size:
      56.8 KB
      251
      File size:
      53.1 KB
      232
      File size:
      39.9 KB
      249
  11. RustyDog
    RustyDog Member
    Lakeland, Fl
    and the rest.
      File size:
      43.7 KB
      228
      File size:
      35.5 KB
      247
      File size:
      45.9 KB
      249
      File size:
      40.7 KB
      236
  12. 1951chevy1ton
    Near Sleepy Eye MN
    Thanks Rusty
    That thing looks like its built better than a brick outhouse!
    Jerry
    Still waiting on Dead Zone Joe to reply.
  13. RustyDog
    RustyDog Member
    Lakeland, Fl
    I know it is strong enough to hold the weight of the truck with the front end up on the back of a rollback, and then it was drug for at least 10' like that. I really enjoyed watching the tow truck driver earn his money. Ended up putting 2 4x4 posts and a couple of planks to get the wheels high enough to keep the hitch from dragging. Ah, the joys of a steep driveway.
  14. Tubby
    Tubby Member
  15. Tubby
    Tubby Member
  16. SinclairChevy
    Keokuk, Iowa
    Tubby,
    Wow, thanks for the photos!!! Those bumpers are pretty cool. The second part to my Sinclair Chevy project will be a trailer, since my grandpa also rented trailers out of his Sinclair service station. It'll be a while before I can get to the trailer part, since the truck is taking me so long, but putting one of these bumpers on the truck while I'm building it might be the ticket to prepping for the trailer project later on.
    Damon
  17. 1951chevy1ton
    Near Sleepy Eye MN
    Thank You
    Thank You Tubby, You Da Man! That gives me some info to design from!
