ol' chebby
- Joined
- Dec 11, 2007
- Messages
- 3,167
- Reaction score
- 27
- Location
- Charlotte,NC
- Website
- www.rpettycustommurals.com
This is what comes in the kit. Very complete, nice parts, US made.
Cut out the template from the instruction book. Place over half round hole where door striker used to live. Trace the outline on the door.
Cut out hole, I used an angle grinder with a cutoff wheel. Now fit the latch plate and mark holes on door face.
Drill holes with 1/4" bit, lower hole to 1", I used a unibit. Also cut hole for linkage to go through...
Grind off the little nub right here...
Mount up latch and plate using hardware provided. I found that I needed a little more clearance(than specified on the template) for the latch to fit easily.
Grind out the rivet that holds the linkage to the actuator.....
Then bolt linkage to latch through the hole you drilled. Don't over tighten, as this is a pivot point.
