54 Chev P/U 3/4 ton front steering Does anyone know if I could use a 1/2 ton bolt on steering arm that bolts to the spindle (that the tie rod connects to) and use the 1/2 ton tie rod would interchange ? The steering arm is just a little shorter and will allow room for the 8 lug rim without using the split rim. It looks like it will fit - has anyone tried this? Thanks Guy
