1958 & 59 Chevrolet 3200
Discussion in 'Trucks for Sale' started by 58Apache250, Nov 22, 2009.
  1. 58Apache250
    58Apache250 Member
    Darlington USA
    For sale 1958 3200 Fleetside. (3B58N) 305 4V, Toploader 4 spd, 12 Bolt Rear.
    truck is driven daily, and has been VERY dependable. Have all the trim, has rust in usual places, but not as bad as some I've Seen. Suspension is in good shape & takes Grease, Steer Tires are showing a very slight Crown, But treads are still 70% After 30K Miles. All the Lights work, the factory turn signal switch is fully operational, and cancels, Wiring harnesses are neat and taped. Glove box clean & intact. fuel tank sealed with the tank liner that Classic parts sells, Gauge Works, All Steel Fuel Lines (Only rubber is at Flex Points (Cab & Engine) New rear Wheel Bearings, Axles, & U-Joints. Brake System Will Be Serviced 12/1/09 (Last Serviced 10/17/09). Rear Tires 65%. Clear SC Title. comes with 1959 3200 Big back Window (3B59L) Stepside(No Title) for parts. extra Rims, weather strip, Headlight Buckets, and saginaw side loader 4 spd. sold as a package only, will not separate or part out.
    $6500.00 Firm.
    More pics Upon request...... Apache25058@yahoo.com
      File size:
      158.9 KB
      740
      File size:
      161.3 KB
      713
      File size:
      156.3 KB
      696
  2. 58Apache250
    58Apache250 Member
    Darlington USA
    Thank You!
    Truck Is Sold, Will Still Be on Forum From Time To Time. Still Have Mama's '73 to finish..............
