1959 Apache 3200 heater
Discussion in '1955-1959' started by 1948Plumber, Oct 8, 2020.
  1. 1948Plumber
    1948Plumber Member
    I have the original recirculating heater in my 59. It currently has a 2-speed switch. Can I install the deluxe switch (see attached pic) to run the heater? It also has an option to direct the heat to defrost. has anyone cut defrost ducts into there 59?
  2. Bill Hanlon
    You can use the deluxe switch.
    The recirculating heater in my '57 GMC had a little flap right at the end of the duct that forced air to the floor. When the flap was shut it forced air up the defrost hoses to the defrost vents that bolt to the underside of the dash. I don't remember that there was anything to cut. I think (but wouldn't bet my life) that GMC and Chevy used the same recirculating heater, maybe with a different label.
    Anyway, I think all you would need was the vents, a recirc heater and a few feet of defroster hose (available at any FLAPS).
  3. Bill Hanlon
  4. 1948Plumber
    1948Plumber Member
