1960 Chevy Apache 10 fleetside pickup truck, light green, 6 cyl, straight drive, column shift, 1995 inspection sticker, stored under carport since then,86K miles. It has been stored under a carport. In 1993 new shocks were added in front and new wheel bearings, brake shoes, and rocker arm assembly were installed. Engine had the bottom end rebuilt about 20,000 miles ago. The carb was rebuilt last week and new points, condenser and coil added. The engine cranks and runs. It will need brakes, new battery installed, and old gas removed from tank. Bring a battery and listen to the truck engine run. The valves need adjusting. There are blisters in paint at bottom of front fenders. Windshield is cracked. In bed of truck, a metal plate covers the original wooden bed. A great project! Live a little, drive an old truck!
FREE Spare parts that come with the truck are worth a lot of money: hood, dashboard, instrument cluster panel, whole heater, manifold with oil filter attached, transmission, 3 carbs. 336-765-8312 evenings, North Carolina. email for pictures: [email protected]. delivery. Reduced from $2750 to $2500. Since I dont come to the forums often, best for you to use your email server and email me directly at [email protected]. thanks
