hello,
I want to build disc brakes from a 1971-72 C20 on my 1969 drum brakes C 20
pick up,I do have all ready a disc brake set and a the suspension of a 1971
C20 pick up
I noticed that the steering knuckles from the 1971 disc pick up,(at the section where the cones where the upper and lower ball joint are situated), the material much thicker is than on the 1969 with drums,and the A arms are going to be further from each other than on the 69 drums
Is it possible to swap the steering knuckels and use the coil from the disc pick up with out problems
except to check up on the caster/camber,
and an other master cylinder
And are there any other problems that somebody know's of
any advice is welcome
Thanks,
Nico (Neterlands)
C20 pick up
Thanks,
Nico (Neterlands)
