1972 rear end swap
Discussion in '1967-1972' started by 1972c10guy, Aug 21, 2015.
  1. 1972c10guy
    1972c10guy Member
    southern Alabama
    I have a 1972 c10 and I've been looking for a whole rear end but no one has one. I've been looking to swap a rear end from a 70 or 71, but I was told I couldn't because of the trailing arms. I want to stay away from welding the arms and i want to do it kinda right. Also I can't find anyone to rebuild it. Can someone point me in a direction I could go?
    vwnate1 likes this.
    Rear End Swaps
    I thought they were all interchangable from '67 ~ '72 .
    What's different in the one you wanted to use ? .
    Have you looked closely at and measured the two rear ends to check ? .
    I have a '69 C/10and have not yet needed to swap a rear end but am always looking in the Junk Yards hoping to find a limited slip one .
  3. My-Kill
    My-Kill Member
    Falls City, Nebraska. "Small Town, USA!"
    You can swap rear ends as long as each truck has trailing arm/coil spring suspension. No welding involved however, the 71 and 72 rear ends are slightly wider than the previous years. Dont quote me and if memory serves (which it dont anymore) the 71 and 72 have 1-1/2" inch wider rear axle housings so as long as you stay 71-72 it should interchange, I've done several...More info would help, like whats wrong with the existing axle? Is it a 12-bolt? Got any pics? ~Mike Hill~
    vwnate1 likes this.
  4. Roger Grubbs
    Roger Grubbs Member
    I want to go to a 3.73 gear instead of the 4.10 in my 72 c-10 half ton. I swapped to a 350TH trans and it is way too low. What vehicle should I look for find a swapper?
    vwnate1 likes this.
  5. vwnate1
    Another similar series 1/2 tonner with the automatic trans......
  6. Roger Grubbs
    Roger Grubbs Member
    Makes sense. Do you know of any newer models? Or maybe identifications of rearend chunks that will fit the rearend I have.
    vwnate1 likes this.
  7. vwnate1
    Sadly I do not .
    As mentioned here there are many different ratios available, I try to fine the year and ratio I want in a package I know will fit .
    Gotta count the # of bolts holding the center 'chunk' in then count the splines where they go into the spider gears .
    For me it's easier to match the lug nuts then measure backing plate to backing plate and spring perches......
    Sorry I can't be more help .
    Someone here will know, it may take a while for them to reply .
